OSD Locked
7 Jun 2010
Tamworth
Hi me again
On my IIyama ProLite E2210HDSD monitor when I try to access the monitor settings via the buttons underneath i get a message displayed saying "OSD Locked".
Is there a way to unlock this or is it or is it locked by manufacture?
On my other monitor same model it isnt locked.
I had this, really annoying actually.
If you hold the menu + up it will display a bar timer and turn the lock off / on
Also if you hold the menu + down it will lock out the power button
