OSPF and Vlans
29 May 2012
UK
Hello all,
Did not know where to put this but here it goes.
I have three routers and switches and they are running OSPF as the backbone for the routers and the computers can ping within each other but i can't get one pc from router to ping the other computer on another router.
Any ideas?
Cheers
What are you trying to achieve with three routers?
I'll PM them to you.
Just upload them to imgur or imageshack etc, and link them here and then you will likely get some better responses. Posting a network diagram is hardly a case of national security - just obscure any internet facing IP Addresses
using cisco i presume?
have you got the command passive interfaces default command present ?
alos i presume you have the network statements for each vlan in there?
This is a forum for collaboration - post your config and people will help you. Ignore VLANs for now, they don't have anything to do with OSPF, it's easier it you refer to subnets.
Post a network diagram and the output of show route, and the config. If you can't post it because it's confidential then pay a consultant.
