OSX afp / cifs network drive problems
28 Nov 2003
EC1V
I have a network drive connected to my PC and Mac through a router. They used to both find the drive fine. Now, for reasons I haven't figured out the Mac cannot make a connection via AFP://. It tries, it looks, brings up connect to server password window (so it finds it and gets the name at least) then it says mount failed once the password is entered.
Before this morning it would hang at that last stage for absolutely AGES and most of the time I gave up and restarted the Mac rather than have an unclosable window floating around.
I'm resorting to connecting via smb:// and it feels very slow and get wierd filesystem issues like being unable to capitalise a folder name as the folder "already exists with that name". The folder then appears twice in the finder with both "stuff" and "Stuff" and identical contents. But the PC sees them as one, and has no issues connecting as usual.
It's a Lacie external, formatted to EXT3. I've tried another Mac which then had the same issue as mine. Any ideas appreciated!
Lacie Ethernet Disk mini?
I got rid of mine because SMB was too slow to do anything, and AFP wouldn't work half the time.
Have you tried clearing the password, switching to FAT32, disabling then re-enabling AFP, aligning it to true north, turning round clockwise three times and clapping your hands? ;)
Honestly, the Lacie was the biggest pile of crap I've ever used. I couldn't get it working properly, so I got rid of it.
Oooow. Not the hoped answer :)
I'm investigating other options, just want a daily shared work drive that is quick to backup. This one is doing funny things and it's now really annying.
