- 1 Sep 2005
- Scottish Highlands
Right, I'm trying to get the following script to work in OSX, but it's not having ball. Any idea where I'm going wrong?
defaultuser.command
logoutscript.command
The basic plan is to copy the contents of the default local user folder to the user template folder, so that whenever a new user is generated, it takes all the settings etc of the default user.
It should then copy the logoutscript.command and set it to run on logout. This script simply removes the contents of the temp user, so it is regenerated on login. At the moment though it is doing none of that and simply sits there after launching it from finder. I have set them both as executable as well.
defaultuser.command
#!/bin/bash
cd /System/Library/User\ Template1/
sudo ditto -rsrcFork English.lproj/* English.lproj.bak
sudo rm -rf /System/Library/User\ Template1/English.lproj/*
sudo cp -R /Users/default/* /System/Library/User\ Template1/English.lproj/
sudo chown -R root English.lproj
sudo chgrp -R wheel English.lproj
cd /Volumes/USB2/
sudo cp /Volumes/USB2/scripts/logoutscript.command /System/Library/Custom\ Settings/
sudo chown a+x /System/Library/Custom\ Settings/logoutscript.command
sudo defaults write com.apple.loginwindow \ LogoutHook /System/Library/Custom\ Settings/logoutscript.command
#!/bin/bash
sudo rm -rf /Users/temp/*
