Hi,
Been trying to decide on a new case for ages, the Fractal Design Define R3 Midi Tower Case [http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-FD&groupid=701&catid=7&subcat=1556] looks like it's almost perfect and has great reviews but I would appreciate it if anyone could suggest any others I should also look at to compare. The R3 is probably a little more than I need, ie. I don't need that many drive bays and I'm not sure I like the door on the front and certainly don't need the holes in the back for external water cooling! There is so many cases I don't know where to start!
My requirements:
Midi Tower
Spec to go in Case: Q9400 2.66Ghz CPU, 8GB RAM, GTX 460, 2xHDs, 1xSSD, 1xDVDR
Black
Quiet with sound absorbing material a bonus
Good Cable Management
Reasonable Cooling Performance
Occasional Gaming
No Water Cooling apart from possibility to change stock Intel heatsink/fan to an All-in-1 Hydro CPU Cooler or bigger quieter fan in the future
Reasonably Future Proof
Look Good/Without Door on the front if possible
Thanks!
My requirements:
Midi Tower
Black
Occasional Gaming
Thanks!
