Other Drive for Vista Docs
28 Nov 2006
Vancouver...from Glasgow
I keep all my docs on another drive (On the D drive not the C drive)
Now with Vista's bloddy document stuff i cant find a way to change it. In XP you could just change the location and everything would be cool.
But Vista seems like it doesnt allow this and has a Chris folder on the desktop that isnt any use to me.
Does anyone know how to change it so that it recognises my D drive as the My Docs place?
Cheers
same as XP:
Ah ok i get it. You have to do it with every different bit, docs, pics, vids etc.
Thanks for the help
andshrew said:
Any idea how you get it to show the proper icons for documents etc instead of a drive icon you get after moving it to another disk?
Yes make a Directory in the drive you want to use for those folders and point at that rather than the drive.
ahh, i was wondering that too.
that's a pain, if it's the only thing on the partition I'd rather it wasn't in a subdirectory. nevermind.
also, I don't think iTunes works well with a moved music folder.
