Other than price, different between these two mobos?
16 Mar 2016
Rubber Dinghy Rapids Broo
currently looking for a cheap mobo to pair with a 6700k, a 1440p ultrawide monitor and a gtx 1070 and cant tell the different between these two motherboards
https://www.overclockers.co.uk/asus...151-ddr4-micro-atx-motherboard-mb-695-as.html
https://www.overclockers.co.uk/asus...151-ddr4-micro-atx-motherboard-mb-684-as.html
do these also qualify for the turbo warranty?
also looking for a nice looking case, cheap ram, and a PSU which would be able to cope with a vega upgrade if anyone has any suggestions,
Would i be able to tighten the ram timings if i were to put 2400mhz cl16 ram in one of these boards as they would only run at 2133mhz?
If they have the options available in the bios then you should be able to tighten them up. All depends on what you can and cannot tweak. They probably lack most options being a non-overclocking board but may have basic tweaking options.
