From the splog.txt file. Says that I should consult the stress.txt file, which I cant find anywhere.
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 1791 Time: 15
CPU: 2401MHz FSB: 266MHz [266MHz x 9.0 est.]
03/07/2007 11:15
Launching 2 threads...
1:Using CPU #0
2:Using CPU #1
1:Beginning a continuous self-test to check your computer.
2:Beginning a continuous self-test to check your computer.
1
ress Stop to end this test.
2
1:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
2:FATAL ERROR: Rounding was 0.5, expected less than 0.4
2:Hardware failure detected, consult stress.txt file.
2:Torture Test ran 0 minutes 23 seconds - 1 errors, 0 warnings.
2:Execution halted.
1:Torture Test ran 0 minutes 23 seconds - 0 errors, 0 warnings.
1:Execution halted.
03/07/2007 11:18
2:Using CPU #1
1:Using CPU #0
2
1
03/07/2007 11:18
1:Using CPU #0
2:Using CPU #1
1
2
2:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
1:Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
2:Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
1:Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
2:Test 4, 4000 Lucas-Lehmer iterations of M19174369 using 1024K FFT length.
1:Test 4, 4000 Lucas-Lehmer iterations of M19174369 using 1024K FFT length.
2:Test 5, 4000 Lucas-Lehmer iterations of M18874369 using 1024K FFT length.
1:Test 5, 4000 Lucas-Lehmer iterations of M18874369 using 1024K FFT length.
2:Test 6, 4000 Lucas-Lehmer iterations of M18874367 using 1024K FFT length.
2:Test 7, 4000 Lucas-Lehmer iterations of M18474367 using 1024K FFT length.
1:Test 6, 4000 Lucas-Lehmer iterations of M18874367 using 1024K FFT length.
2:Self-test 1024K passed!
2:Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
1:Self-test 1024K passed!
1:Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
2:Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
1:Test 2, 800000 Lucas-Lehmer iterations of M163839 using 8K FFT length.
2:Test 3, 800000 Lucas-Lehmer iterations of M159745 using 8K FFT length.
1:Test 3, 800000 Lucas-Lehmer iterations of M159745 using 8K FFT length.
2:Test 4, 800000 Lucas-Lehmer iterations of M157695 using 8K FFT length.
1:Test 4, 800000 Lucas-Lehmer iterations of M157695 using 8K FFT length.
2:Test 5, 800000 Lucas-Lehmer iterations of M155649 using 8K FFT length.
1:Test 5, 800000 Lucas-Lehmer iterations of M155649 using 8K FFT length.
2:Test 6, 800000 Lucas-Lehmer iterations of M153599 using 8K FFT length.
1:Test 6, 800000 Lucas-Lehmer iterations of M153599 using 8K FFT length.
2:Test 7, 800000 Lucas-Lehmer iterations of M147455 using 8K FFT length.
1:Test 7, 800000 Lucas-Lehmer iterations of M147455 using 8K FFT length.
2:Test 8, 800000 Lucas-Lehmer iterations of M143361 using 8K FFT length.
1:Test 8, 800000 Lucas-Lehmer iterations of M143361 using 8K FFT length.
2:Self-test 8K passed!
2:Test 1, 560000 Lucas-Lehmer iterations of M212991 using 10K FFT length.
1:Self-test 8K passed!
1:Test 1, 560000 Lucas-Lehmer iterations of M212991 using 10K FFT length.
2:Test 2, 560000 Lucas-Lehmer iterations of M210415 using 10K FFT length.
1:Test 2, 560000 Lucas-Lehmer iterations of M210415 using 10K FFT length.
2:Test 3, 560000 Lucas-Lehmer iterations of M208897 using 10K FFT length.
1:Test 3, 560000 Lucas-Lehmer iterations of M208897 using 10K FFT length.
2:Test 4, 560000 Lucas-Lehmer iterations of M204799 using 10K FFT length.
1:Test 4, 560000 Lucas-Lehmer iterations of M204799 using 10K FFT length.
2:Test 5, 560000 Lucas-Lehmer iterations of M200705 using 10K FFT length.
1:Test 5, 560000 Lucas-Lehmer iterations of M200705 using 10K FFT length.
2:Test 6, 560000 Lucas-Lehmer iterations of M196607 using 10K FFT length.
1:Test 6, 560000 Lucas-Lehmer iterations of M196607 using 10K FFT length.
2:Test 7, 560000 Lucas-Lehmer iterations of M194561 using 10K FFT length.
1:Test 7, 560000 Lucas-Lehmer iterations of M194561 using 10K FFT length.
2:Test 8, 560000 Lucas-Lehmer iterations of M188415 using 10K FFT length.
1:Test 8, 560000 Lucas-Lehmer iterations of M188415 using 10K FFT length.
2:Test 9, 560000 Lucas-Lehmer iterations of M186369 using 10K FFT length.
1:Self-test 10K passed!
1:Test 1, 4500 Lucas-Lehmer iterations of M17432577 using 896K FFT length.
2:Self-test 10K passed!
2:Test 1, 4500 Lucas-Lehmer iterations of M17432577 using 896K FFT length.
1:Test 2, 4500 Lucas-Lehmer iterations of M17432575 using 896K FFT length.
2:Test 2, 4500 Lucas-Lehmer iterations of M17432575 using 896K FFT length.
1:Test 3, 4500 Lucas-Lehmer iterations of M17115073 using 896K FFT length.
2:Test 3, 4500 Lucas-Lehmer iterations of M17115073 using 896K FFT length.
1:Test 4, 4500 Lucas-Lehmer iterations of M16815071 using 896K FFT length.
2:Test 4, 4500 Lucas-Lehmer iterations of M16815071 using 896K FFT length.
1:Test 5, 4500 Lucas-Lehmer iterations of M16515073 using 896K FFT length.
2:Test 5, 4500 Lucas-Lehmer iterations of M16515073 using 896K FFT length.
1:Test 6, 4500 Lucas-Lehmer iterations of M16515071 using 896K FFT length.
2:Test 6, 4500 Lucas-Lehmer iterations of M16515071 using 896K FFT length.
1:Test 7, 4500 Lucas-Lehmer iterations of M16297569 using 896K FFT length.
2:Test 7, 4500 Lucas-Lehmer iterations of M16297569 using 896K FFT length.
1:Self-test 896K passed!
1:Test 1, 5300 Lucas-Lehmer iterations of M14942209 using 768K FFT length.
2:Self-test 896K passed!
2:Test 1, 5300 Lucas-Lehmer iterations of M14942209 using 768K FFT length.
1:Test 2, 5300 Lucas-Lehmer iterations of M14942207 using 768K FFT length.
2:Test 2, 5300 Lucas-Lehmer iterations of M14942207 using 768K FFT length.
1:Test 3, 5300 Lucas-Lehmer iterations of M14155777 using 768K FFT length.
2:Test 3, 5300 Lucas-Lehmer iterations of M14155777 using 768K FFT length.
1:Test 4, 5300 Lucas-Lehmer iterations of M14155775 using 768K FFT length.
2:Test 4, 5300 Lucas-Lehmer iterations of M14155775 using 768K FFT length.
1:Test 5, 5300 Lucas-Lehmer iterations of M13969343 using 768K FFT length.
2:Test 5, 5300 Lucas-Lehmer iterations of M13969343 using 768K FFT length.
1:Test 6, 5300 Lucas-Lehmer iterations of M13669345 using 768K FFT length.
2:Torture Test ran 1 hours, 14 minutes 53 seconds - 1 errors, 0 warnings.
2:Execution halted.
1:Torture Test ran 1 hours, 14 minutes 53 seconds - 0 errors, 0 warnings.
1:Execution halted.
