My rev 1 EVO 120 appears to have been overcome by my A64 X2. Heatpipes too small to shift enough heat up to the fins, I think. It performs very well within its limits, but an X2 is past its limits. So, I need a new cooler and I haven't been looking at them for a couple of years.
Looking around, I'm currently leaning towards a Tuniq tower, It isn't too expensive, seems to do very well in tests and doesn't need a lot of clearance. On S939, does it use a K8 backplate or the standard retention mechanism? I'm hoping for the backplate, as I have one on and I don't want to bother taking my motherboard out to remove it and refit the retention mechanism (if I can find it).
I'm using an Asrock 939 Dual SATA 2 board, so whatever I buy needs to fit on that.
