'out of range'?
25 Oct 2004
hey guys. wasnt sure where best to post this so apolagies if it belongs somewhere else. My mums monitor has suddenly started showing 'out of range' on the monitor. from boot, everything displays normally, even the windows loading screen but just before windows actually loads up and displays, that message comes up on the monitor. there is only one display out on the pc, a vga so i cant try another connection to see if that sorts the problem. has anyone got any suggestions or any ideas why this might have suddenly happened.
oh, by the way, the pc is some crappy pre-built system from pc world with a 9400 in it.
thanks for any help in advance:)
The resolution has been set in the options too high for the monitor to display.
Change it using safe mode I think works.
