Out of SATA ports :/ ... options?
Caporegime
13 Jan 2010
Llaneirwg
So i went to install my new hard drive and found i am out of sata ports, 5 are taken up by HDDs and one is taken up by esata front port.
what is the best option to sort this? ive come up with..
get a slow USB 2 caddy/dock
get an esata caddy/dock
swap motherboards.. do not want to do this cause of the hassle!
unless im missing something?
unfortunatly i have 2 6950s taking up 4 slots, a pci-e tv tuner and a pci wireless card .. all pci/E slots are taken, the only one i could remove is the pci wireless for a usb.. i doubt a pci would have the bandwidth would it?
How often do you use the esata port, could you give this up?
How critical would speed be needed on this drive, as you mention you could use USB.
Get rid of the raptors and buy an SSD. Much faster :)
Buy much larger hard drives.
Use en eSata to sata cable and loop cable into case. (I have done this)
If i had an ssd it would still take up 2 sata slots, one for the SSD one mechanical for games etc, not convinced by SSD either
i already have 2x 1.5TB for media storage, the new drive is a 2 TB drive, cant really see much gain in swapping the 1.5s for 2s
i tend to use the esata to backup my OS drive to external
there literally is 2mm gap between the GFX cards
this drive is going to be a media storage drive only [ie music, blu rays etc]
best suggestion so far i think is disconect the front esata
also, am i right in thinking pci [not E] cannot support sata II? cant see any cards like that anywhere
Time to go for a seperate server . . . .
Or a NAS box, or a drobo (Can also use firewire if your board has it)
i have been contemplating this.. would need a 4 bay box and they all seem very expensive.. would prefer NAS
you have five sata ports and obviously need a lot of storage
- ssd for booting
- 4x 2TB drives
that would be quick and have a tremendous amount of storage :)
i find my 2x wd VRs are better than 1xssd and 1xmech for games, both take up 2 slots, and i dont like to mix storage with games, therefore i gain no sata ports.. the 2x VRs hold my OS, not as fast as an ssd but snappy, and all my games docs apps.
i would swap my 1.5s for 2s but the resale price is too small for 500GB extra
drop thw wireless card and add a usb wireless card and a pci sata card. the storage drives wont mind being only on sata 1.5
Other option is to get a USB drive, which is fine for media storage, but it will take you a day of copying to get it filled up with stuff.
stop using your esata front port, and use your esata rear port + a cable so you can still backup to your other drive etc, and plug it into one of your 6 internal sata ports.
use a firewire drive, still not that fast, but better than usb.
get an esata caddy and have it plugged into your back port
stop using esata for backup (and just use usb) and use the esata for the new drive.
drop your blu ray drive and get an external one
Considering your board has 6 int. ports and a rear esata port, and you have 4 drives, an external and a blu ray and you want to add another drive, I dont see what your problem is, since thats 7 sata cables going into 7 ports. Did you simply forget you already have a rear esata port?
