Hi guys,
My outdoor tap has been leaking for ages. It was just an odd drip until I had a water softener installed and I think the plumber took the pressure restricter off the mains pipe.
I decided to attempt to fix it this weekend by applying more PTFE tape to the leaking joint. Unfortunately the tap snapped off in my hand. It looks like it may have been over tightened at installation and the thread snapped. Half of the thread is in the pipe and half of it is attached to the tap.
Photo of the tap:
(snapped at the white tap bit where it was leaking from)
Will I need a plumber to fix this by taking it back to the L joint which is screwed to the wall or is there any way of getting the thread out of the tap?
Cheers
Photo of the tap:
Cheers
