Outemu Blue switches, can you make them a little quieter?
17 Mar 2018
Hi
I just got a new keyboard and i love the click from the blue switches but they are a little loud on the bottom out. they have this strange anti wobble sides around the mx compatible stem so i dont think you can use the rubber o ring method, so what could i do?
Is it definitely the bottoming out that is noisy? If so, this is generally amplified/massively dependent on keyboard construction and desk surface. Metal midplates can add or remove noise here. Placing the keyboard on a desk mat/mouse mat might help. O-rings would too, sadly.
Edit: is this the stem? An o-ring might still work here.
cxixPg
Short of modifying the keyboard with MX Whites not really - even adding damping stickers won't help as it's the inside of the switch that's making the noise, not the shaft.
Then what do o-rings normally do?
They hit switch frame/housing before key cap can hit it or stem bottom.
Pics in here seem best, but depending on how high those supports are, not sure if o-ring would reach switch frame before something else bottoming.
That cross shaped Cherry MX key cap attachment point looks to be little shorter than those key cap supports.
https://www.kitguru.net/peripherals...et-8178-rgb-mechanical-gaming-keyboard/all/1/
Actually o-rings might make key caps sit little higher.
