Outlook 2007 (Beta) Not rendering
5 May 2004
Northern Ireland
None of my emails are rendering and Outlook is throwing up a message about it not being able to render emails. Can anyone shade any light on this matter?
Blackvault
Running some kind of email virus checking? If so its possible it has nuked all your emails.
Try swapping out your old .pst file for a new one, disabling your AV and sending yourself a test message. If you recieve it ok then that is your problem.
Otherwise try waiting for the technical refresh, which should be out late next week.
Blackvault said:
where is the .pst file?
Blackvault
C:\docs + settings\local settings\application data\microsoft\outlook
If you move it out of the folder, Outlook should prompt you to make a new one when you open it (therefore backing up your old emails incase they can be recovered)
Do you have Word 2007 installed? I think Outlook uses the rendering engine that is part of Word 2007. I'm not using it myself but this is what a mate told me. I've left a msg for him to get back to me if it is any different to this.
Blackvault said:
I haven't got a .pst file in that location :confused:
Blackvault
Try doing a search for it (remembering to click to include hidden files + folders, system folders etc), it will normally be called Outlook.pst
If you don't have a .pst file that will be your problem, the .pst file stores all your emails, so no pst = no emails.
Well I am recieving emails :mad:
Blackvault
i had this problem earlier today! a tempory fix it to delete the .ost file and start again.
but the culprit is AVG - ive uninstalled it and its now working fine. if you have AVG installed then i guess it might be that.
(Im using outlook to connect to my uni exchange server over http)
