When I create a new email message and click the “to” button it only brings up the global contacts etc which I assume all come from the exchange server. There is no option to send to any of the contacts I have stored within in Outlooks “contacts”.
I’ve had a quick search on Google and it seems to suggest that you need to enable the contacts to be used as an address book but when I try this I the box is greyed out and you cant tick it!
Screen shots incase you dont have a clue what Im talking about above!
There should be a contacts option here under public folders?
Thanks for any help
Thanks for any help
