Outlook folder confusion : Advice please!!
4 Feb 2004
Écosse
Hi,
I'm using Outlook 2007.
At the moment, I have 5 seperate email addresses in there.
Just now, everything pretty much comes in to my Inbox in one big fat lot. :p
As an Outlook newbie, I want to have email for each seperate address be received and go into its own folder so its easier to navigate everything.
I'm not sure how to go about this though?.
Thanks. :cool:
You need to look at Rules (Tools->Rules and Alerts)
Create a new blank rule,
Choose Start From a Blank Rule -> Check messages when they arrive -> Next
Tick Through the specified account (bottom box, click on specified and choose account) -> Next
Tick move it to the specified folder (click on specified)
Now, down the bottom of this list is stop processing more rules - I recommend you tick this one, unless you want further processing within the split - then click next until the rule is created
HTH,
André
