Outlook forwarding
24 Sep 2005
Middlesbrough
For some reason on Outlook 2000, ALL emails sent to the main mailbox are being forwarded to the personal folders inbox.
How do you stop this?
I've gone into the properties on Outlook and selected that all new mail should be sent to the main mailbox.
This hasn't worked.
On Outlook 2003 you use:
Tools -> Email Accounts -> View existing account and there is a dorop down box for Deliver new mail to the following location.
Don't know if 2000 is exactly th same but must be something similar.
If that doesn't work, check there are no rules in operation.
Think I may have done it.
Can't access the accounts that way in 2000 I don't think.
But you can with you rightclick on Outlook and go into the properties that way when you assign an exchange server.
Thanks.
