Outlook Group Policy Settings
Baz
Baz
9 Dec 2002
Peterborough
Probably straight forward, but I am struggling with this one..
I am installing Exchange 2007 this weekend from Exchange 2000 and can't get to all the PC's to alter the Email Settings.
I have seen in Outlook 2007 Group Policy templates that you can specify the Exchange server, but there is nothing in the Outlook 2000/2002/2003 templates.
What's the easiest or best way of deploying these settings, as I am sure in large environments they don't go to every PC :confused:
Thanks
I already use that for when I rolled out Office 2007 across the business..
but I have 2000/2002/2003 Outlook clients as well
Which will only work with Outlook 2007.
When I went from 2003 to 2007, it automatically changed the Outlook configuration when the user opened outlook. I just left the old 03 server running for a while and did the rest manually. Dont know if it will work with 2000 though
This is what I am trying not to do, as we have remote clients, who are not computer savvy and struggle to open a program unless it is on their desktop!
Apologises I have just re-read your original post. I would have thought Outlook 2003 would have picked up the new server where the mailbox is located. I'm unsure about Outlook 2000. Looking at your posts I would suggest doing what Iaind said and do them manually but that depends on the numbers etc.
If you leave the old server online long enough (to account for people being on holiday and things) everyone should get switched over - I was only left with 1 or 2
Thanks, both servers will be online together, and I was going to migrate all at once..
Outlook 2007 is the easy one, we have around 60 people on that, the other 60 are on a mix of older versions...
Outlook 2003 definitely changes the setting for you when you move the mailbox - testing outlook 2000/xp should be easy enough
Leave the existing exchange server switched on for a suitable amount along with your new one to accommodate for you users being on holiday or sick leave. Your Outlook profiles will update for you as the users connect.
Was going to say, AutoDiscover should do this. Also the mailbox location is stored in an Active Directory attribute so that should also point the client in the right direction.
