Caporegime
- 13 May 2003
- Warwickshire
Calling network geeks!
Not sure if this is best placed in here or software...here goes anyway.
I sometimes use my work laptop via my home cable connection (Virgin) and from behind a router.
I normally connect to my work emails via webmail in a browser window. Recently I tried to use Outlook and discovered that Outlook hangs as soon as it loads. Everything else seems to work fine, browsing internet and files, etc.
When I bypass the router i.e. connect the PC directly to the cable modem, Outlook works fine. I have added the necessary port forwarding rules for SMTP in the router menus (it's a typical D-Link cable modem) and tried placing my PC in the DMZ, with no joy.
IT have looked into it, but have drawn a blank so far. I think they think it's not worth the effort when I can just use Outlook Web Access, but I need to be able to edit my calendar, reminders, notes etc. offline when I have no access to the internet and have it sync with the server when back online at home.
Any ideas network geniuses? What about Outlook from behind a router is causing a problem?
