Outlook help!
16 Oct 2007
UK
Hi all,
Trying to use Outlook 2007.
All the pop settings are 100% fine - manually entered them, used the provided reg from Cpanel, settings in Outlook Express work perfectly.
But when I go to Send & Recieve, it says
Task '[email protected] - Receiving' reported error (0x800CCC0F) : 'The connection to the server was interrupted. If this problem continues, contact your server administrator or Internet service provider (ISP).'
Sending, however, works fine.
And the error immediately comes up after pressing send/recieve, no attempting at all
I've made a new Mail profile, pointed it at the account, re-entered the settings, done EVERYTHING I can think of!
Any ideas?
Ok, managed to fix it, and should anyone else have this issue..........
Seems like incoming server needed SSL connections, but Express didn't!
