Outlook - IMAP?
18 Oct 2002
Around
Does anybody know if Outlook 2003, when using IMAP, can be set to put Sent mail into an IMAP folder (called Sent Mail) instead of putting it in its Local Folders? Same goes for Deleted Items.
I've hunted through the options for ages but can't find out how to do it....am I being blind or can Outlook 2003 not do this? :o
Cheers
your imap provider has allows you to create your own folders on the server? mine doesn't - i only have an inbox folder and that's it.... :p
anyway you should be able to create a rule to move the messages when they are sent. look under tools>rules and alerts. :)
