Outlook Web access problems
4 Sep 2005
London
Hi all
I was messing around with the callendar sync settings on my phone, and managed to sync my university timetable twice to my Uni OWA calendar.
On OWA now, I have twice as many entries, and I can't find out where to remove duplicates. It's annoying because now my phone calendar has my timetable twice.
Has anyone got any ideas? I tried adding my university account to Outlook to see if I could get any further, but it wouldn't let me add my account.
Thanks
I dont think you'll be able to now. Even though they are clearly duplicates - they most likely have unique "IDs" so Exchange/Outlook will see them as unique. Because of that - I don't think exporting and re-importing (and chosing not to import duplicates) would work either.
I've had a similar problem, what i ended up doing (in Outlook) was change the calendar view to show all appointments, then add the "date created" field (not there by default), then arrange them by date. Then you could be able to see the new (duplicates) all bunched up - which you can then delete!
