OK, heres the situation, the GTX 680 obviously has 2x DVI, DP, and HDMI.
I have a TV hooked up to the HDMI and my system monitor hooked up to displayport.
Now when the system boots, I dont get any signal on the system's monitor until windows starts.
If I want into the BIOS, it will display on the TV instead, and not the monitor.
Is there any way to give DP priority over HDMI?
I do have the option of just using DVI for the monitor, but I prefer DP, the cable is thinner, easier to route, and it doesn't have those stupid screws sticking out half a mile from the back of the case.
Any suggestions?
Any suggestions?
