- 28 Jan 2005
- Southport
Hi all,
I am thinking of installing some outside sockets for easier access for the lawn mower etc, save running an extension cable through the house which with a 2 year old isnt ideal.
I am looking at something like this:
http://www.toolstation.com/shop/p27175?table=no
Couple of questions... with this being classed as a special install with it being outside will I need to apply for inspection under part p? I have read not as its not altering internal wiring and is deemed as temporary?
I will be plugging it into the sockets in the utility room which from what I can tell is on a 20a breaker at the CU using 2.5mm2 cable (Written on the CU). If i was to use an extension from the newly installed outside sockets will this be ok as long as im not loading it up too much?
The whole house was re wired before we moved in back in 2014 so nice and up to date. I have 2 RCDs at the CU already but I presume with the RCD on the socket anything tripping from outside will just trip this kit rather than the rest of the stuff on the RCD at the CU?
