- 20 May 2009
So I have my newly built pc - i am typing away happily on to you right as you read this.
I have decided to do a bit of overclocking, unlinked the memory whatchamacallit and put in a a multiplier of 9 x 350 giving my duo6600 (2.4) a healthy 3.06 ghz mark. I did get it higher by simply plugging in a higher multiplyer value - 3.33 ghz this morning, but then I read on here that you need some decent cooling beyond 3,2 so I brought it back down.
Now with the core temp software I am getting readings of 25 degrees and 29 degress presumably for each respective core.
I was wondering whether thats a combined temperature, because some readings went up to 40 and 50 - so that would equal 90 degrees!? thats super hot!
I have left the cpu voltages at auto and i think its something like 1.35 or something like that, but to get higher that 3.33 ghz do I have to change the cpu voltage as well as all the other voltages like for the memory etc? Or is it primarily about cpu voltage when overclocking,
sorry if this is super basic and Thanks!
