Oven Repairs?
20 Feb 2004
Hondon de las Nieves, Spain
We turned our oven on the other week and it tripped the power. The oven still works but the bulb had gone.
I got a replacement bulb and came to switch it out but it must've blown pretty bad as it had cracked the glass cover and part of the bulb almost looked melted.
The bad part here is that a replacement bulb did bugger all and so i suspect the issue to be within the oven itself. Does anyone know the best way to go about trying to fix it?
Its probably about 30 months old now and is a Bosch which looks similar to this but i'd need to check the exact model number at home
http://www.bosch-home.co.uk/our-products/cooking/ovens/ovens-range/HBA63B261B.html?source=browse
It had a two year warranty, so I would contact Bosch & explain what has happen, their customer service is very good, I had a Bosch washing machine which died about four months outside of the warranty replace, contacted Bosch, it was replaced with a brand new one foc.
Maybe I was just lucky.
