Oven unit. Adding under drawer
Caporegime
21 Oct 2002
Here
Any off the shelf kits to convert my wickes 600mm oven unit with a bottom blanking plate into a usable drawer?
seems simple as a concept but am I missing something? Maybe there are no drawers short enough ?
We were going to do something similar, but the drawer unit took up so much of the space. Our filler was only about 150mm high from memory, if that.
In the end, I fitted some hinges so it was essentially a flap that dropped down. Useful space for baking trays, pudding trays etc.
Nice. What hinges did you get. To make it work. Assume the hinges mount inside the unit ?
mine is a 130mm
I had a double oven and originally intended to buy a 10cm filler but then realised IKEA do 10cm drawers. Went in no problem. Unfortunately a week later the oven blew up so I went with a separate single oven and integrated microwave which meant I had to remove the 10cm drawer to make space :p
That's what we looked at, as we have some other Ikea units with drawers which are great.
We just felt the space taken up by the actual draw, would make it less usable. YMMV
I could not get my muffin/Yorkshire pud tins in the drawer, but they fit in the space nicely now. :p
Yeah, IKEA.
We had similar but I ended up converting the small bit plus the bottom of the kick board.
