over clock settings are they okay i7 3930k
8 Aug 2011
Hello. Sorry this is long winded but
I just overclocked my 3930k to 4.6ghz i just wanted to know if i am using safe settings for 4.6ghz my motherboard is asus rampage iv extreme
Extreme Tweaker Menu Ai Overclock
Tuner: X.M.P
CPU Level Up: Disabled
Bclk freq: 100.000
CPU Strap: 100MHz
ClockGen Full Reset: Enabled
Turbo Ratio: By All Cores
By all cores : 46
CPU Clock Gen Filter:Auto
Memory Freq: DDR3-2133mHz
Extreme Tweaking: Disabled
EPU Power Saving Mode: Disabled
Extreme OV: Enabled
Bclk Skew: Auto
CPU Vcore : Offset Mode
Offset Mode Sign:+
CPU Vcore Voltage: +0.015
VTT CPU Voltage: 1.1
2nd VTTCPU Voltage: 1.05
CPU VCCSA Manual Voltage: 1.1
DRAM V (A, B): 1.50 DRAM V (C, D): 1.50
CPU PLL Voltage: 1.65
PCH Voltage: Auto
VTTDR Voltage (A, B): Auto
VTTDR Voltage (C, D): Auto
CPU Spread Spectrum: Disabled
PCIe spread specrum disabled
Digi+ Power Control Submenu
CPU Load-Line Calibration(LLC): Medium
CPU current capability: 180%
CPU Voltage Freq: Manual
Fixed frequency:500
VRM Over Temperature Protection: enabled
CPU Power Duty Control: T.Probe
VCore MOS voltage Control: Auto
CPU Power Phase Control: Extreme
CPU Vcore Boot Up Voltage: Auto
VCCSA Load-Line Calibration(LLC): High
VCCSA Current Capability: 140%
VCCSA Fixed Freq: 300
CPU VCCSA Boot Up Voltage: Auto
CPU VTT Switching Freq: 1.3x
CPU VTT Over-Current Protection: enabled
PCH Switching Freq: auto
CPU Performance Settings Submenu:
CPU Ratio: auto
Enhanced Intel Speedstep Technology: Enabled
Turbo mode: Enabled
Power Limit Control: Auto
Advanced Menu CPU Configuration Submenu:
Intel Adaptive Thermal Monitor: Disabled
Hyper-threadiCPU enabled
cpu Power Management submenu
CPU Ratio: Auto
Enhanced Intel Speedstep Technology: enabled
Turbo mode: Enabled
CPU C1E: Enabled
CPU C3 Report: Disabled
CPU C6 Report: Disabled
CPU C7 Report: Disabled
Monitor Settings Anti Surge Support: enabled
Right now after a couple of prime tests and linx i am getting 75C max and i am getting max voltage of 1.360 according to cpuz an temps via core temp
is there anything wrong running that way or anything I should change to reduce volts an temp?
Many thanks
Power Limit Control: Auto change to Enhanced on enable
You know you dont have to change every setting to overclock. have you tried the basics.
boost on
Multi up
Vcore UP
some of the setting will put extra heat into the CPU and may not even be needed with your chip.
Ran into a problem. I can run real bench and every other benchmark an system runs fine I start playing games with my oc ram and after 30 mins pc locks up. How ever when I leave all ram settings on auto and just alter v core an llc an things I am 100 percent stable very odd more tweaking needed as it's well strange that I can bench it an mem test it but as soon as I cam it locks up with no bsod or error. Temps are 68 on cpu, gfx cards 65. Running 2 780ti in SLI. How ever I don't have the additional power cables connected to the board as I don't have a floppy power lead. The only thing I could give extra power to it gfx card's with my psu.
