I thought this would be fun, as it's often a hot topic in any LED / LCD thread.
Plasma die hards argue that LED (full array) LCD look oversharp... I myself like this look.
What I propose is this sharpness is the actual sharpness in the video source, and not done by over processing in software by the set.
I think LED LCD by very design produces a crisper picture to the eye, if this was not the case and it was all software trickery, plasma manu's would also do this to wow joe average in the highsteet.
As it stands in high street stores the LED LCDs look far better and impressive.
I think the points above prove that plasma, with it's softer look is in fact the more artificial look (the softer look is created by the panels lighting method itself) ...and LED LCD is the more accurate reproduction of the video source.
I know a lot of plasma owners calibrate etc etc.. but as much as you get accurate colours / contrasts, the inherrant 'softness' of the picture is still there.. at least to the eye, which seems to be unable to cope with per pixel lit displays. If this wasn't a issue you would see desktop plasma for your PC.
If plasma doesn't have inherrant 'softness', then why does OLED look so much sharper ?. Is it all down to IR ?
The real world is sharp, at least if you have 20 / 20 vision, why would you not want that on your TV ?
Discuss
Discuss
