- 24 May 2006
- North Wales
I'm doing my first major attempt at overclocking, and I would like peoples advice on where to go to next:
Specs:
e6750
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Current settings:
FSB at 410MHz
CPU at 410x8 = 3.28GHZ and 35C under load with 1.375V (not 100% load, prob about 80% load)
RAM at 984MHz and 5:7:7:23 timings (can these be tightened? to what level?)
If I go for a FSB of 420MHZ the system freezes, even when the CPU multiplier and RAM divider are slowed down
When I cranked up the northbridge voltage the PC wouldn't even post at 420MHz. Any ideas how to push that up? (think n00b things I might have missed!)
Finally, my monitoring software is saying system temp of 44C with a CPU temp of 35C. Could I be getting a mis-reading from one/other or can CPUs run at a lower temp than the case? (i do have a Antec P182 case with a Noctua NH-U12F heatsink)
Thanks in advance
Fluffy Sheep
Specs:
e6750
Current settings:
FSB at 410MHz
When I cranked up the northbridge voltage the PC wouldn't even post at 420MHz. Any ideas how to push that up? (think n00b things I might have missed!)Finally, my monitoring software is saying system temp of 44C with a CPU temp of 35C. Could I be getting a mis-reading from one/other or can CPUs run at a lower temp than the case? (i do have a Antec P182 case with a Noctua NH-U12F heatsink)
Thanks in advance
Fluffy Sheep
