Overclock and Build Noob - Can you help
9 Nov 2011
Apologies for the questions which may seem basic to you clever guys
I’m an overclock noob 
I’m looking to build a gaming / workstation (for processing large digital images)
I think I’m after an i7 2600k with over clock, 8gb ram, a good but not the best (due to cost) gpu. I’ve listed some questions and would be grateful for advice
1. What OC
I’m not sure what OC to select. Clearly I want extra power but not at the risk the CPU / MoBO / Peripherals being at greater risk of expiry due to being overworked. Hope this makes sense. There are multiple OC, stage 3 at 20% seems OK; I feel wary about max OC’s in case this impacts stability and / or life of CPU & RAM etc. However as I said I’m an OC noob.
2. What MoBo
Considering the above, using socket 1155, there is a range of Mobo’s e.g. P8P67V, P8P67Pro, P8268v etc
I want a good mobo but no point spending money for features I want use, unlike some of you clever OC guys. Perhaps the P8268v is sufficient
3. What GPU
As always, the best GPU is overpriced, second best and below are always a fair bit cheaper as is always with leading edge elements.
I have no affiliation to nVidia or ATI having used both in the past. I also always get confused as whether to buy a single card now and in the future consider an SLI / xfire buying the same but now cheaper 2nd card to pair it with or to in future sell current card on ebay and buy another 2nd / 3rd best card of the future as a replacement etc, hope this makes sense
Screen wise I have single 24”monitor, no plans for dual monitors. I’m sort of thinking the ATI 6950 2gb, or 6970 (but may be too expensive)
4. What Case
A good case, with cooling abilities considering the OC but not something too expensive where I could use the money elsewhere. Needs to fit under a desk. I have had a Cosmos S in the past, one with touch on/off button rather than press button and it was a disappointment as it started switching itself off sometimes, drove me mad
5. Budget
I thinking around 1200 / 1250 incl VAT. I have no Blueray DVD’s, I like I having 2 DVD trays, why don’t OC offer option of a 2nd tray? I don’t really know enough about having an SSD cache (20Gb) to consier it or am better off spending the money on other components e.g. I don’t mind waiting a few extra seconds for it to boot-up. I’d rather have a fast rig when running / better utilities
I’d be very grateful for your advice. It’s a lot of money to spend and I want to get right.
you definately want a z68 motherboard :)
GPU is this i think: 6950 2gb = 560ti
6970 2gb = 570
so it depends on resolution and the games you play :)
Cases:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-212-CM&groupid=701&catid=7&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-LN&groupid=701&catid=7&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-221-CM&groupid=701&catid=7&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=CA-013-LN&groupid=701&catid=7&subcat=
All of theese are viable cases but its really a preferance thing.
If you asked for a second dvd drive im sure they would put one in, ssd's are great for loading times so putting your favourite game on there can be a bonus :)
I love the look of this case :D http://www.overclockers.co.uk/showproduct.php?prodid=CA-057-CS&groupid=701&catid=7&subcat=
Thanks for taking the time to reply Greavesy
OC - Do I need to worry much about the I7-chip expiring early if OC'd ?
Z68 - I assume standard is OK, no need for Pro
GPU's - do you guys favour single cards over xfire/sli etc per my scenario above
cases - nice selection -
Cheers
Well i think Intel actually have guidlines for the oc but you should hit 4ghz on air without affecting the life span just get a nice air cooler like the gelid tranquillo :)
Motherboards:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-360-GI&groupid=701&catid=5&subcat=1990
http://www.overclockers.co.uk/showproduct.php?prodid=MB-458-AS&groupid=701&catid=5&subcat=1990
http://www.overclockers.co.uk/showproduct.php?prodid=MB-054-AK&groupid=701&catid=5&subcat=1990
I have the second one (asus) and its pretty good. The asrock board will allow you to use pcie 3.0 with an ivybridge processor but i dont think its really worth the premium.
The gigabyte and asus will be good enough :)
A single card is good enough, I think the recommended settings for BF3 on a HD 6950 is ultra settings on 2560 x 1440 so 1 card is enough :)
Greavsie - Thanks again, I think Asus will do it
Smed - I use CS4 so same thing. i wonder what the actual performance difference is? Is it tiny or significant
I'm nearly sorted now, thanks guys!
I really couldn't tell you. Something about NVIDIA has CUDA so faster rendering times? Sorry I can't be more helpful, that's just what I've read. :p
Thanks again guys. It appears I'm going to go over my budget :(
I think I've settled on the Corsair Carbide 500R case. Its starting to get good reviews for a case under £90 plus most importantly its got good cooling and an in built fan controller.
So its that case, i7-2600k with OC, 8gb ram, 2 DVD optical drives, GTX 570 or ATI 6970 I'll read-up more) and a 1tb WD cavier SATA HD at 6gb/s 64mb cache (this should alleviate the need for a small SSD cache drive) and Corsair 650w psu
Thanks again for your help, its a confusing place sometimes with to much to choose from
build it and overclock it yourself, I'm sure someone will be along and post links to 'how to build pcs' you tube links.
for overclocking ask in the overclocking section of the forums once you've got the pc up and running.
do you have any old sata hard disks you can reuse? as the prices are crazy at the moment. do you need the os?
cpu http://www.overclockers.co.uk/showproduct.php?prodid=CP-360-IN&groupid=701&catid=6&subcat=1275 think this should enough for your needs
but if you want i7 http://www.overclockers.co.uk/showproduct.php?prodid=CP-358-IN&groupid=701&catid=6&subcat=1859
motherboard http://www.overclockers.co.uk/showproduct.php?prodid=MB-493-AS&groupid=701&catid=5&subcat=1990
or http://www.overclockers.co.uk/showproduct.php?prodid=MB-491-AS&groupid=701&catid=5&subcat=1990
ram http://www.overclockers.co.uk/showproduct.php?prodid=MY-299-CS&groupid=701&catid=8&subcat=1517 if you go antech kuhler 620
or http://www.overclockers.co.uk/showproduct.php?prodid=MY-290-CS&groupid=701&catid=8&subcat=1517 if you get air cooler
cpu cooler http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-AN&groupid=701&catid=57&subcat=1395
or http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-GD&groupid=701&catid=57&subcat=1395 good for 4.5/4.6ghz
psu http://www.overclockers.co.uk/showproduct.php?prodid=CA-009-LA&groupid=701&catid=123&subcat=
or http://www.overclockers.co.uk/showproduct.php?prodid=CA-047-CS&groupid=701&catid=123&subcat=
the 700/750w gives you option for xfire/sli in the future
graphics card 6950/560ti, if using photoshop then guess you'll want 560ti
http://www.overclockers.co.uk/showproduct.php?prodid=GX-267-AS&groupid=701&catid=1914&subcat=1341 bit on the expensive side but comes with 2 games, can sell them if you don't want them
case personal choice
os(if needed) http://www.overclockers.co.uk/showproduct.php?prodid=SW-127-MS
dvdrw £15-£20 no real right/wrong choice
blueray(if you want, but don't go oem as you don't get blue-ray playing software which you need and no free options available from what I've read)
http://www.overclockers.co.uk/showproduct.php?prodid=CD-138-SA&groupid=701&catid=10&subcat=314
ssd http://www.overclockers.co.uk/showproduct.php?prodid=HD-009-CR
or cheaper http://www.overclockers.co.uk/showproduct.php?prodid=HD-008-CR
hard disk(if you don't have any old ones) http://www.overclockers.co.uk/showproduct.php?prodid=HD-081-SA&groupid=1657&catid=1660&subcat=1664
