Hi Guys
Hope you can help, I've tried Afterburner, EVGA Precision and CAM and all give me the same problem.
I setup my overclock in whichever program, save profile where required, select to apply the overclock on startup and make sure the program is loading at startup.
However if I then reboot machine, load up Heaven and then click to show whicher overclocking program when I actually run Heaven the card will just go to standard boost speed, even though all the overclock programs (only have 1 installed at a time) will show the overclock settings I've saved.
If I then for example in Afterburner, click the profile an apply, the core jumps upto the overclock speed. Same on the other programs.
Not really sure what I'm missing as the programs will load up at boot an all are set to apply the overclock at startup.
Any help would be massively appreciated
