Assuming thats idle with speedstep enabled by the x6 multi. So you have a 3.2ghz overclock. Have you tested it on full load with a stress test like Prime95 or intelburntest? Also did you set your voltages manually or left them all on auto? Readings on them would be nice to see.
if in bios hardware monitor > voltages or similar. In windows you can download everest to see the voltages there. Also forgot to ask what are idle and full load temperatures like? you can read them with program like realtemp, coretemp.
