I've overclocked using the auto function on my motherboard and looking at CPU-Z it says that the "Uncore Frequency" is 2250.2 MHz. so does this mean my memory is running this high? also the voltage level for the memory is 1.650 Volts is this to high? (i've pasted part of the CPU-Z report below)
Thanks
Chipset
Northbridge AMD 790FX rev. 00
Southbridge AMD SB700 rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual, (Unganged)
Memory Frequency 600.0 MHz (3:8)
CAS# latency (CL) 8.0
RAS# to CAS# delay (tRCD) 8
RAS# Precharge (tRP) 8
Cycle Time (tRAS) 20
Bank Cycle Time (tRC) 27
Command Rate (CR) 1T
Uncore Frequency 2250.2 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 2048 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CMX4GX3M2A1600C9
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.2
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-23 @ 444 MHz
JEDEC #2 8.0-8-8-22-30 @ 592 MHz
JEDEC #3 9.0-9-9-24-34 @ 666 MHz
XMP profile XMP-1600
Specification PC3-12800
Voltage level 1.650 Volts
Min Cycle time 1.250 ns (800 MHz)
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-6-6-16-27-2T @ 533 MHz (1.650 Volts)
XMP #2 9.0-9-9-24-41-2T @ 800 MHz (1.650 Volts)
Thanks
Chipset
Memory Type DDR3
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 11.25 ns
Min tRCD 11.25 ns
Min tWR 15.00 ns
Min tRAS 30.00 ns
Min tRC 50.63 ns
Min tRFC 110.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
