Overclock Checkup :)
Permabanned
7 Jul 2005
Suffolk
I just want to make sure im not killing anything or doing something i shouldnt be.
as im new to this.
Temps:
Cpu -roughly 39c/43c idle
Mobo - 33c
Gpu - 44c/50c
Name AMD Athlon 64 3700+
Code Name San Diego
Specification AMD Athlon(tm) 64 Processor 3700+
CPU Clock Speed 2420.2 MHz
Clock multiplier x 11.0
HTT Bus Frequency 220.0 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 1024 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2420.2 MHz (Full)
DRAM Size 2048 MBytes
DRAM Frequency 220.0 MHz
FSB DRAM CPU/11
CAS# Latency 2.0 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 2 clocks
Cycle Time (TRAS) 5 clocks
Bank Cycle Time (TRC) 11 clocks
DRAM Idle Timer 16 clocks
Command Rate 2T
# of memory modules 2
Module 0 Corsair DDR PC3200 - 1024 MBytes
Module 1 Corsair DDR PC3200 - 1024 MBytes
Graphics card: Xfx 7600 GT
Core bus 600Mhz
Memory bus 800mhz
any suggestions on any changes are apreciated!
Stock should be 2.2
What MB are u using?
Your idle temps are to high, what HSF are u using, put your rig in your sig makes it easier for everyone
i decreased the cpu voltage a bit, now its running the same speeds but at 1.36 with a c of 36 :), but that could be because its not as hot and muggy as what its been all weekend
i understand you can get better speeds by decreasing the cas latency and multiplyer ect.. but would this give me a massive boost in gaming?
Command Rate 2T?
CPC enabled? Its ment to be 1T mate.
Change CAS to 2.5, mem voltage to 2.8C CPU voltage to 1.45V, 180 (or 166) divider and start clocking!!
after reading the newb sticky iv made a lot of changes.
CPU Clock Speed 2608.2 MHz
Clock multiplier x 10.0
HTT Bus Frequency 260.8 MHz
L2 Speed 2608.2 MHz (Full)
Memory
DRAM Type DDR-SDRAM
DRAM Frequency 217.4 MHz
FSB:DRAM CPU/12
Nvidia ntune also says the memory clock is 331 MHz and the HTT multiplier is 5x.
is the DRAM Frequency and clock right??
Command Rate 2T
