- 6 Sep 2008
- Near Hull
Hi
Not really done any overclocking before and from what i've read you should first increase the FSB of the motherboard through the bios.
the processor is an amd athlon 6400+ @3.2Ghz, starts with a FSB of 200 and multiplier of 16. as soon as i try up the FSB a little bit it fails orphos stress tess and prime95.
the computer boots and seems to run fine( not gaming) at 3.57Ghz but i really need it stable.
CPU: Amd athlon 6400+ BE
RAM: 2x1GB Corsir XMS2 5400
Motherboard: Asrock Alive SATA 2GLAN (sucks)
just need to know what setting i could try changing.
I have it running at 3.4Ghz right now and was just playing Race Driver GRID perfectly fine, but i tried running orphos and got:
Type: Small FFTs - stress CPU Min: 8 Max: 64 InPlace: Yes Mem: 8 Time: 15
CPU: 3393MHz FSB: 200MHz [212MHz x 16.0 est.]
17/12/2008 17:08
Launching 2 threads...
Using CPU #0
Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 800000 Lucas-Lehmer iterations of M172031 using 8K FFT length.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 0 minutes 1 seconds - 1 errors, 0 warnings.
Execution halted
It just fails seconds into the test.
17/12/2008 17:08
Using CPU #0
Execution halted
