Overclock hz on my monitor?
12 Jan 2012
England
Would it be safe to increase from 60hz (native) to 70hz on my Asus VE228H 22" Widescreen using Nvidia control panel?
By safe I mean not blow up immediately but I don't mind if it shortens the life slightly.
Native is:
Resolution
Frequency = 1920x1080
Horizontal
Frequency = 67.5(P)
Vertical Frequency (Hz) = 60.00(P)
Pixel (MHz) = 148.5
You won't blow anything up. I think you'll just find the screen shows an "Out of range" type message. That's probably because it will hit the limit of what refresh rate X resolution can achieve. At 1920 x 1080 and running at 60Hz the screen is already at the limit. If it could do more then it would probably be listed in the specs.
