Hi,
I've been trying out the BF4 beta and was maxing out my stock i2500k CPU, so decided to try a bit of overclocking to see if it would help. I think i've done a fairly simple overclock - I just whacked the turbo multiplier on all the cores up to 42, then played with the voltage until i got a stable 5-10 mins in intelBurnTest. Currently set at 1.24V and load line levelling on Level 5.
When running the burn test i was getting temperatures up to 78 or so, but playing BF4 for half an hour they only went up to about 65. Do these temps look ok? I know my cooling solution isn't great (specs below) - is there a simple change i can make to improve these if they need improved (or to allow me to get to 4.5 GHz or so if it would make a difference)?
Case - unknown mid-tower, limited space.
Intake fan (front) - Arctic F12
Exhaust fan (rear) - Arctic F12
CPU heatsink - Arctic Freezer pro Rev2
The intake fan is reporting that it spins at 1000 rpm tops, but it should be 1350 afaik. The exhaust fan reports 1400 rpm, which looks ok. The fan on the CPU heatsink should be a 2500 rpm, but reports top speed of 2100 rpm.
Do these numbers look normal? I don't think I'm getting decent airflow on the intake, which probably isn't helping the small fan on the heatskink.
Would it be worth replacing the 120mm intake/exhaust fans to improve airflow (if so what with? only have room for 120mm fans). I have space for an 80mm fan on the side panel, which would blow over the top of the GPU and just behind the CPU heatsink, would that help at all? Or am i looking at replacing the CPU cooler with something like the Macho 2 (i think that's all that will fit, I only have 25-30mm space from the top of the Freezer 2 to the side panel).
Sorry if this is a mess or i've missed out something important - I know the answer is likely to be 'buy a new case' but i don't think i want to do that at the moment unless it works out to be cheaper than adjusting what i already have. Thanks for any advice!
