Overclock isnt staying with me ?
12 Dec 2005
Hey guys.
I overclocked my graphics cards yesterday (6800)
I go back today and check on it, and its reversed its self, i see a box that says "Apply these settings on startup"
Is this the box i click?
Cheers.
- Denic
man_from_uncle said:
Cheers mate, ran 3DMARK, and for some reason, i got 300 less points than last time lol :p. It just must be how it works, like how other things are running on your pc when doing the tests.
Thanks
The nvidia cp is a bit weird when setting new clock speeds. I have to reset my overclock when I change drivers, and I have to do it twice every time.
When you have set the speeds, with "Apply these settings on startup" ticked, you should close the cp and then reopen it. Usually, the mem or gpu speed has reset itself to default, so you have to apply the overclock again. It's as if the cp can only accept one change at a time, so 2 attempts are needed to set new cpu and mem speeds.
