Hi there, I have been trying to OC my RIG :
Gigabyte P965 DS3
2GB OCZ Gold
E6700
Thermaltake 680w Power supply
Antec P180B case
When I set the OC, it POSTS and boots to both Vista and XP without problems. I can run superpi 32M and the temps hardly reach 50.
I have followed the advice in the Gigabyte DS3 thread and upped the voltages etc. So when it runs, it runs perfectly.
The problem is that it keeps resetting. I power it on, set the OC, save and exit. It then boots. If I restart my PC though, it POSTS, resets, POSTS again and all the OC is gone - back to stock 2.66.
I can manually go and OC it each time, it works like that, but it is a pain. Anyone got any ideas as to what may be causing it to reset - and how to override it ?
Mod
Gigabyte P965 DS3
2GB OCZ Gold
E6700
Antec P180B case
Mod
