overclock not enough
29 Jun 2004
i installed a auzentech pci soundcard vista kept freezing, i primed my system and it failed. Could this be the reason for my sound card freezing up when playing games/movies. Ive upped the vcore and am re priming and have been ok since.
Hi,
I don't know anything about the Auzentech sound cards + vista, but if you've primed your system and it failed, then that'll be the reason, system instability can make problems in lots of different ways, your new sound card may have triggered some instability.
If upping the Vcore a little has solved the instability, then I guess your problem is solved.
Banjo
