overclock not working and causeing memory problems
22 Feb 2011
about 2 months ago i purchased a motherboard bundle it consisted of a asus p7h55-m motherboard, a i3 530 dual core processor, a nero s cpu cooler and a corsair 2 2gb stick memory kit. its all been put together probably as ive had it checked ive also had over clockers replace the memory.
the problem im having is un clocked it runs lovely its just not what i payed for.
over clocked it blue screens with different error reports im running windows 7 and have both versions 32bit and 64bit
64bit is fine for 20 mins then memory dumps as soon as you try to do other than sit on the desktop like playing a dvd.
32bit gets to going into windows and memory dumps straight on the music entry
just to inform anyone im running 2 seperate 750gb sata hdds, a seperate graphics card which is a EAH4770fml pci express running standard, and a seperate sata dvd drive.
all drivers are up to date and as i said this system is completly fine until over clocked who is having the same or similer problem i really need to resolve the issue here.
thanks to all that might be able to help
