Overclock - nVidia Quadro K5000M
21 Nov 2019
Hi
So I've just overclocked my laptop's nVidia Quadro K5000M to try and save myself from an endless nightmare of driver modifications required to install a Quadro M5000M or P5000M.
After initially flashing a custsom vBIOS onto the card using nvflash I had the stock clock speeds up from 601MHz to 758MHz. And a lot of MSI afterburnering and benchmarking testing later, I settled at a final speed of 1108MHz. Whilst that number isn't great in the grand sceme of things I'm proud of it, since this 7 year old Quadro almost doubled it's stock clock speeds, any modern GPU doing that would be unheard of.
Now I admit this post is fairly niche but I do however have a few questions, and had a few raised eyebrows whilst in the process of this overclock.
Firstly: This one's just out of curiosity, if anyone else reading has also OC'd the K5000M, what frequencies were you able to get, and is 1108MHz on core comparable to what you achieved?
Secondly: This is a weird one, and those with a keen eye may have spotted it already. When talking about the overclock, I purely mentioned core clocks, and not memory. For some reason if I try and adjust the memory clock, MSI afterburner will just reset the sliders for Core clock and Memory clock back down to 0. Does anyone know if this is a problem with MSI afterburner, the K5000M or something else?
Here's an image below of my overclock whilst running unigine valley - at least there should be but for some reason it didn't work. (yes I know there's much better benchmarks out there but I standardised on this one a while a back and don't really see a need to change, at the end of the day a better card will still get better framerates no matter what benchmark you use (usually) so what's the point!)
https://ibb.co/k66rsQH
k66rsQH
Hola
Así que acabo de hacer overclocking en la nVidia Quadro K5000M de mi computadora portátil para tratar de salvarme de una pesadilla interminable de modificaciones de controladores necesarias para instalar una Quadro M5000M o P5000M.
Después de flashear inicialmente un vBIOS personalizado en la tarjeta usando nvflash, obtuve velocidades de reloj estándar de 601 MHz a 758 MHz. Y después de muchas pruebas de postcombustión y evaluación comparativa de MSI, me establecí en una velocidad final de 1108MHz. Si bien ese número no es muy bueno en el gran escenario de las cosas, estoy orgulloso de él, dado que este Quadro de 7 años casi duplicó sus velocidades de reloj estándar, cualquier GPU moderna que lo haga sería inaudito.
Ahora, admito que esta publicación es bastante específica, pero tengo algunas preguntas y algunas cejas arqueadas durante el proceso de este overclocking.
En primer lugar: este es solo por curiosidad, si alguien más que lee también ha hecho OC en el K5000M, ¿qué frecuencias pudo obtener, y es 1108MHz en el núcleo comparable a lo que modificó?
En segundo lugar: este es extraño, y es posible que aquellos con buen ojo ya lo hayan visto. Cuando hablé del overclock, solo mencioné los relojes centrales y no la memoria. Por alguna razón, si trato de ajustar el reloj de la memoria, MSI afterburner simplemente restaurará los controles deslizantes para Core clock y Memory clock a 0. ¿Alguien sabe si esto es un problema con MSI afterburner, el K5000M o algo más?
Aquí hay una imagen a continuación de mi overclock mientras ejecuta Unigine Valley; al menos debería haberlo, pero por alguna razón no limitada. (sí, sé que hay puntos de referencia mucho mejores, pero estandaricé este hace un tiempo y realmente no veo la necesidad de cambiar, al final del día, una mejor tarjeta seguirá obteniendo mejores velocidades de cuadro sin importar qué punto de referencia usted use ( generalmente), entonces, ¿cuál es el punto?)
k66rsQH
[/CITA]
Hi, I'm really surprised how often you were able to get :")
I tried but I couldn't :'(
Could you help me telling me where to download or could you share the modified bios?:')
