Overclock OK?
17 Aug 2010
Hey, first time overclocking and ive just overclocked my i5 760 to 4.2GHz, getting around 35°c idle and 60 ish under load. These are my settings.
Thanks
Your IMC voltages seem high. Have you tried turning them down? I'm not too sure with the i5's if the memory controller is on the CPU or chipset. If they are on the chipset then turning them down will reduce the temps too.
Might sound lame but i've got an i7 and I've been able to run a 4Ghz OC with just 1.6 volts.
I did turn them down too and I fount about a 5 degree drop.
Try lowering all voltages until you start to fail ibt/prime etc.. then go up a notch each time and test. Should shave off a few degrees easily.
