This thread has evolved from my previous topic on the discussion of upgrading from 32Bit to 64Bit.
Chapter Two of the 64bit story:
Without further ado I emailed OCUK's support via web-note with my query, the correspondence can be seen below albeit in a 'snipped' form:
Reply from Support:
My reply to first response:
And finally their second reply:
And that brings us back to present day.
It seems, according to what I've been told so far that there is little support for a newbie overclocker to overclock a 64bit system utilising - to quote - "more RAM than needed".
But now that 64bit is slowly becoming the standard, most prominently in the client-side market where overclocking will have quite a large foothold on system builders, surely people will want to have more than 2GB of RAM and at the same time want to overclock that system without having to be an expert. When will this support be in place, and what options are there for us relatively newbie OC'ers to have this cake, and eat it?
Perhaps something should be added to the beginners guide to overclocking to adddress this issue.
I apologise for the very long post and I know this won’t be an issue for most. But for those of us that want to upgrade and don't want to have to compromise this seems like quite a dilemma.
I acquired Windows 7 64bit Professional from my university and before doing a clean reboot (upgrading from XP) I wanted to know how much I could squeeze out of those juicy 64bits. The obvious thing everybody knows about is the higher memory capacity. I thought "fantastic, I'll just order some extra RAM, job done".
But something came to my mind, I fairly recently made a modest overclock on my E6600 @ 3GHz. Of course to overclock you need to alter some RAM settings.
This brought up a question about my proposed RAM upgrade. Surely the new RAM won’t like the fact that my RAM timings and voltages are altered. 'Simple' I thought, I'll just reset the BIOS, reverting the overclock, timings, voltages to factory state, install the new RAM and then re-apply the overclock. But I better check with somebody 'in the know' first.
{From me}
...[SNIP]...
I currently have 2GB of PC2-6400 of GSkill RAM and was considering buying some more RAM to reach my current maximum of 6GB.
However, as I have overclocked my CPU and changed my RAM timings I was wondering how that would affect me? Can I just install the new RAM without any problems or do I need to change/modify anything first?
...[SNIP]...
Reply from Support:
{Reply from support}
The simple truth is; if you have an overclocked CPU and you want to insert more RAM into the system, you have to choose between the OC'd CPU or the extra RAM. As the extra RAM wouldn't allow for there to be an overclock on the CPU...
So obviously, you have to make a decision on what you want your system to be for mainly, if it's a gaming system go for the extra CPU power, if you're looking to use programs like the Adobe suite more often than most, then go for the extra RAM, really.
...[SNIP]...
{From me}
Thanks for your email. I'm afraid I'm quite confused.
My motherboard can handle 8GB, but I already have installed 2GB (2x1GB) of GSkill PC2-6400 RAM. This means using the current RAM I can reach a total of 6GB if I buy 4GB of PC2-6400 RAM (2x2GB) - this is what i planned to do.
The problem is - as mentioned in my initial web note - I have overclocked my CPU and altered my RAM timings to adhere to the overclock.
...[SNIP]...
If the addition of more RAM will have an issue with an already-in-place overclock then what steps do I need to take in order to have my CPU overclocked with the new RAM? Or is it just impossible to overclock the CPU with more than two memory slots occupied?
Can't I remove the overclock, reset the RAM settings, insert new RAM and then re=overclock?
Surely there must be many people who have overclocked their system, then bought 64Bit, then wanted to take advantage of the higher RAM capacity but also wanted to either keep their overclock or re-overclock once the new memory is installed? Or is this just not possible?
...[SNIP]...
{Second reply from support}
When you add more RAM to an overclocked CPU and Motherboard, the RAM pretty much can't take to the voltages that you've amended them too, so you'd risk just not throwing enough power into your motherboard to get the RAM working properly, really.
But yes, you're right - there are people who have overclocked their CPU and had 8GB of RAM, and gone for a 64bit OS, but obviously it takes a lot of trial and error - and I couldn't mean that in any better way, overclocking with more RAM than needed usually means failure is going to take place, and you can somewhat guarantee you're going to either short your RAM or motherboard, or maybe the CPU - it's something our techies don't recommend you do unless you have extensive experience. The one thing which deters people from doing the OC on a CPU with 8GB of RAM, is the fact that the OC itself wouldn't even be high enough to justify all your effort - so people usually just leave it at stock value.
...[SNIP]...
