Overclock p8p67
3 Mar 2008
Hi i want to overclock, my I5 sandybridge, to 4.6,
i did have a pdf from overclockers showing step by step how to do this, does it still exist? I lost me settings when i installed a new bios.
Basically what i want is a idiots guide to how to overclock it, with picture :)
mucho thanks in advance.
mango
http://hardforum.com/showthread.php?t=1578110
You just want to get it right for your i5 - ie voltages etc
or use this
http://hardforum.com/showthread.php?t=1578249
I recently set up a 4.6ghz i5 offset on a P8P67 mobo
I found it needed +0.05 with all the other settings from post above to get stable so that might help you
You wont need + 0.65 the guy needs to get his i7 stable at 4.8 so dont do that.
Maybe start at -0.05 and see if that is stable.
And obviously monitor your temps - but offset is the way forward mate as your cpu throttles when not working hard - perfect!
