overclock question
21 Jul 2007
hi, i have an AMD 5600+ dual core bla bla...
in bios, i can change the multiplyer and voltage. the multiplyer is set as 14x and thats the highest it will go. the voltage was set at 1.3, i put it up to 1.350 as its the max it will go. made a very small diffrence of a few mhz. is overclocking suppose to be able to make it go better than that or is that about it?
What motherboard have you got? Sounds like it's got limited overclocking options unless it's got a separate Vcore Overvolt option somewhere.
Jokester
