- 1 Nov 2013
- Ireland
I have a H97 Pro Gamer, I thought it had limited OC options enabled recently, but it doesn't - no way to overclock the CPU.
How can I get my 2400mhz ram to run faster than 1600mhz? If I set XMP it runs at 1600mhz, bios by default sets it as 1333mhz.
I know I can change the blck: dram ratio, but I'm not keen on doing that as I don't want to make the system unstable, the lowest ratio option the bios gives me would set it at 103mhz.
Are there any other options? The board says it supports 2400mhz by OC but I'm at a loss how to do this.
