- 17 Jan 2006
Hello,
Lastnight I decided to fiddle with my BIOS and I found a little setting that allowed me to auto-overclock my CPU.
I set it to be overclocked by 10% (It gave me options for 3%, 5%, 10%). Everything ran fine and the temps were only marginally higher than normal. After a few mins the pc locked up for a couple of seconds so I rebooted and reset the overclock to 'Standard' i.e. no overclock.
However...
After the POST section where usually I expect to see the Windows XP logo with the little blue/green bar swishing along I get nothing but a black screen.
Nothing happens after that at all.
Have I managed to break something??? Can this be worked around???
System Spec:
Any help greatly appreciated.
However...
System Spec:
- Asus A8V Deluxe
- A64 3000+
- 1Gb Corsair XMS
- 6800GT
). PC booted, but threw up a lot of grabage when detecting HD's (SATA & IDE). What I did is cleared the CMOS, like suggested, & worked. But on 1 occassion had to restore the Windows partition from a backup. Gave up trying to Overclock the board from there on. Apart from that great board nevertheless!
