Overclock voltage question
11 Aug 2007
Hi
Here is my spec:
Pentium Dual-Core E2180, stock speed 2GHz, OC speed 3GHz
2GB Corsair XMS2 DDR2/PC-6400 memory
Gigabyte GA-73PVM-S2H motherboard
GeForce GTX 260, 216 core, 896MB
CoolerMaster Real Power 520W power supply
I'm currently using the stock cooler on the CPU, I used to have an aftermarket cooler but it broke so I had to revert to the stock one. Basically, the stock speed of the CPU is 2GHz and the standard voltage the computer is set to is 1.32500 (I think thats right). But what would I need to up it to for a stable 3GHz OC?
Thanks
